In the last few weeks I have installed a new carb, changed the plugs and checked the timing. It runs well and the fuel economy is up a little bit, but still even with a choke that works it takes 15 sec. or so of cranking to start cold and 4-5 sec. when its warm. I was hoping in addition to other improvements the starting would become easier, this is the only complaint about this motor, I'm begining to wonder if this has something to do with the boat being in the water and having some back pressure. Its been a while since i've had it out of the water but if I remember correctly it does start easier on the dry.
