hard starting
EARLS BOAT
i have trouble getting my 1989 70hp Evinrude started but once started it will start super easy and runs great idels great and has great throttle responce . i think i need a fast idel for starting or some way to give it some throttle. i have checked all the fuel lines to make sure i was not losing fuel or sucking air.
EARLS BOAT
Re: hard starting
I Push Key In To Choke For A Moment As Engine Turns Over And Push The Throttle As Far As I Can Before The Safety Feature Prevents The Engine From Starting. I Have Not Had This Boat Very Long We Are Still Bonding:)!
freddyray21
Re: hard starting
pump the primer bulb until hard. hot key in while starting this will activate the choke. high idle also works well.
EARLS BOAT
Re: hard starting
thanks tashasdaddy! i found out that i have a fast idel after all. like i said i just got the boat and am still getting the feel of it. it is going to be easy starts now!!
kenmyfam
Re: hard starting
Let us all know if everything works out now.
Good Luck.
EARLS BOAT
Re: hard starting
i sure will. you guys are a great help thanks!
