Re: hard starts
after they sit a couple of hours, pump the bulb till hard. fast idle lever all the way up, turn key to on, push in count to 3 and turn key, still holding, release key. should have started, lower fast idle lever to idle. you may have to bump the key in once or twice till the motor settles. you have a primer on that motor, that injects fuel into the intake, when you push the key in. motor does not have a choke, like the 25.
