A friend of mine has a 70's model starcraft (?) w/75 HP Evinrude. It has been in enclosed storage for many years. He is attempting to get it going but discovered he couldn't turn the motor. I took a look at it for him and the first thing we did was grease all the fittings. It did help to loosen up enough to be able to turn the wheel full in both directions, but it is still very tight. Can someone give me a few suggestions to further loosen up the steering? Does the cable itself require some sort of lube, maybe some WD 40 sprayed into the housing? Any help would be appreciated. He'd like to get the boat out on the water. BTW, it does run very well, didn't even have to change plugs or anything. Fired right up. Thanks.....................jg
