40 hp 99/00 model Johnson two stroke electric start.
Turns over great...but....
I read the FAQs. I pump the bulb...then...today...I tried the "hold the key in for a count of ten" trick. No effect what-so-ever. I've tried to pump the key a few times; I've tried starting without any pumping at all. Normally ( about five trips so far) I fiddle and crank and pump and start and stop...she finally starts with a great big roar. I get some white smoke and then she runs just fine all day.
The bulb is a bit soft, so today I bought another line and bulb but have not yet installed it.
Since the introduction of ethanol, I know lots of people here have had troubles with that. On another engine (40 yammie) I also own..I swapped the bulb and fittings and that cured a similar issue this last summer.
I may not have NOT checked the spark plug gap. We put new plugs in when I checked it out initially...but I don't remember if we gapped them or not. Anyone know the correct gap? The engine started fine...but..we had been pumping away for a while before changing out the plugs...so... who knows what that means.
126 lbs on each cylinder. Runs like a top..ONCE I get her going She re-starts fine all day long also....after the initial start.
I originally had it checked out by my Johnson mechanic. He did some adjusting and cleaning of the carb and pronounced her fit. New gasoline. I don't want to take her back to the mechanic because, due to a boat show next week...I probably won't see her for three weeks if I have to bring her in.
?? Any ideas or suggestions appreciated thanks Rich
