Re: Hard to start when engine is hot... Sugg. for troubleshooting please!!
I'm having a similar problem ("Choke Plate Closing After 1 Hour"). What I can add to this thread is that my 1974 Mercruiser 140 (older 3.0) used to start great cold or hot. When cold, pump threee times, crack throttle, started in about 1/4 second. When warm, leave it in neutral at idle, no pump or cracking, just turn the key and it started immediately. Now something has changed and warm starting is painful. Razvanbuc, being careful, taking the flame arrestor off allows you to check the choke plate once the engine is warm (have a fire extinguisher ready). Cold engine, my choke has the choke plate closed lightly, and it opens after a minute or two as the engine warms. But my problem is that after running an hour or so, the choke plate is closing again with lots of tension on the choke coil spring. This floods the engine and makes hot starting very difficult, and I have to go to full throttle so that the unloader will mechanically open the choke plate to lean the mix and allow starting. Maybe your problem is similar, with the choke not acting right when fully warmed.
