Re: Hardest engine to work on????
I have a little word-of-mouth business. I will repair any make engine with mechanical damage but I always note to the owner that I do not have diagnostic tools for electronics so will not repair those problems. I do one or two engines a year--mostly as a diversion.
Believe Me! THEY ARE ALL GOING TO FIGHT YOU IN SOME WAY! So, expect aggravation in every engine you rebuild. But, Force and Chrysler tend to be the easiest to work on.
If you do start it as a small sideline business---CHARGE EM! They expect it! If you do not respect your labor, skill, and knowledge enough to charge a fair price, how can you expect the customer to feel that he/she has gotten a quality repair?
For example: When I rebuild an engine, 1 piston or more--it still takes about 10 hours to disassemble and reassemble. So, I charge 450 labor plus parts for a complete rebuild. 45 bucks an hour is fair considering that the marina will charge 100. I make a little money while doing something I enjoy, the customer saves a little and we both win.
My personal philosophy is to give them a little extra. For example: I usually remove the head(s) while they are present and show them the damage. The river is close, so if at all possible, after the rebuild, I take them out for a shakedown cruise. I regrease the trailer axles as part of the rebuild and will also recommend and persuade them to let me change the water pump impeller. ( be a shame to overheat a brand new engine for a twenty dollar part) I will also dress the prop edges if necessary.
