Harmonic balancer pulley differences between a MercruiserMCM228R and a Mercruiser 898
jimrockireland
I started with a Mercruiser 898 305/5L engine block and swapped over all the engine components from a cracked block 1983 Mercruiser 305/5L MCM228R Serial#6275628. This included the intake manifold, 4 barrell carb, distributor, Thunderbolt ignition, fuel pump, alternator,wiring harness, etc. I also swapped over the 3 upper pulleys ganged together but I did NOT swap over the 3 crankshaft pulleys. The crankshaft pulley on the 898 has a 5 3/4" diameter pulley and the crankshaft pulley on the 228R has a diameter of 6 1/2".. I have essentially ended up with a 228HP engine with a 198HP crankshaft pulley Is this going to create undo strains on the crankshaft since the harmonic balancer pulley was originally mated with the lower HP engine?
Re: Harmonic balancer pulley differences between a MercruiserMCM228R and a Mercruiser
Nope,... It shouldn't matter, it's the same motor, with bigger induction,...
