If you can see the pic of my transom, I have been connecting the tow rope to the tie point directly over the out drive. I'm seeing some pulling out or bowing of the transom above this tow point. I have "submarined" the tube a few times. The transom is aluminum with a laminated wood square between the bell housing and out drive. The wood was replaced a couple of years ago. If you can tell where the tie downs are, do you think a harness that low would be a better setup? I have seen the type with a pulley that are self centering and just a simple Y rope type.
