Re: Has anyone attempted this?
I think you need to get some terminology cleared up so people can make sense of this. You do not power anything other than a spark plug with an ignition coil. The stator windings under the flywheel provide the power for the IGNITION system consisting of an ignition control unit and an ignition coil for for each cylinder. IF and only IF the engine is fitted with a charging system does another set of charging coils appear for that purpose. There is no such thing as "armaturies" but in a conventional generator or electric motor there is an "armature". On an outboard the only armature is in the starter or trim motor. Some small engines had charging systems that could be added as an option where one wasn't originally included. Most electric start outboards already have a charging system. Now then, what is it you are actually trying to accomplish?
