Re: Has anyone ever used a heat gun?
Heat gun is ideal but like you said be careful...they can go 1200 degrees which is WAY more than you need...I did mine with a hair dryer and it worked fine....stay way back away from the boat with the heat gun and heat up just enough to soften the glue and start scraping with a rubber spatula type tool. Once you get the hang of it you can get the end up and start pulling back as you heat and get the sticker off in big pieces ....you'll have glue residue still which comes off easy enough with goof off, goop off, acetone (dont use on painted aluminum , only on gelcoat, or any other type of glue remover.....I took off 2 huge decals on mine in a couple of hours....you will still see the outline of the sticker in the side of the boat most likely as the gelcoat has faded around the sticker....compound and wax the whole boat and it will blend in pretty well....over time and a few waxings and you will hardly be able to see it after a while.
