Have small 1100gph 12volt bilge pump - starts stops starts stops
ozstar
HI,
I am using a 12 volt 1100gph submersible bilge water pump in a drian system in my garden. Ur is a cheapy but it does it's job well.
I have connected it to a small float switch and this is where my problem is I am sure.
When the pump is switched on the pump empties the small tank okay but doesn't stop when the water has emptied. It will run for a while then stop, the after a while start up again then later on stop and so on.
The float switch does not seem to be working as it is supposed to.
Doesn't stop/start when I lift or let it fall as if tank is empty.
Just not sure why it starts and stops after a few seconds then starts and stops again.
Any ideas please
oz
Without knowing the style of float switch or brand of pump. Only suggestion I have is use a quality pump, a quality switch and a check valve on the discharge
Tank is empty and the pump still runs, I would say its the float switch
