JustJiggin
- Joined
- Jun 23, 2008
- 37
I just had to run a new wire that run up under the flywheel where the points and condensers are. The wire that broke connects to a wire that leads to my kill switch. Anyway the wire got wore real bad and ended up breaking just before it went under the flywheel. So I had to remove the fly wheel to get to the wire. While I was at it I cleaned the points and checked everything out on the armature plate. I have the 71 25hp Johnson and I was looking online it seems my motor should have two coils under the flywheel. Mine only had ONE? Now that I think about I could see where another coil was supposed to be. I guess who ever had the motor before me did some work on it. But it sure threw me for a loop. Or maybe I'm wrong about it having two coils where the points and condensers go? Could somebody verify that for me please? The motor still ran very good with the one coil I would have never knew if I didn't have to remove the flywheel to fix that wire. Anyway back to original question after putting everything back together and setting the points to .020 with a gauge, and putting the flywheel back on. I try to crank it and BOOM back fired, it never back fired before. It backed fired several times while trying to crank it. I got the two external coils (not the plug wires but the wires that run to the coils with the plug wires) wires mixed up. I disconnect them and switch the wires and it cranks up. I still have a back fire but it does start up and will run WOT but I know timing can't be a 100% cause it wasn't back firing before I took flywheel off. I do have moon key in the slot so it's not the moon key on shaft. I've been reading about cam timing and timing marks on the flywheel can someone explain a little more in depth about the timing and the flywheel. I really need to get the timing back in time tomorrow. I just put flywheel back on I wasn't aware it had to be timed once you removed it.
