Re: having issue with too high of idle?
ok here is the latest, (1) dont think i have vacume leaks, i sprayed the intake area and rpm did not change,also i put my hand over the carb and it died fast(after almost trying to suck my hand down the carb throat WOW!!) (2) DON S you were right on the money with the throttle cable!! i removed the throttle barrel and readjusted it and brought idle way down,also before this adjustment my shifter was very stiff(up front)going into neutral,drive,reverse(now its smooth as butter) and my carb butterfly was stuck in the open position,and after cable adjustment i could freely flap it back and forth.... (3) i checked my timming following don s instructions in the stickeis by putting in base timming,it was on 0 degrees so i just slightly moved dist.so it read 2 deg BTDC (but she seemed to idle a little worse?)pulled jumper on dist.and reconected switch wires and checked again read about 13 degrees BTDC, but when i killed engine it dieseled once,So i repeted steps and moved it back to 0 degrees base,and 11 degrees BTDC out of base timming,and when i killed engine it did not diesel( and started faster also) so i guess i will leave it set there....engine still seems to have a slight miss though(with rpms down engine shakes a little) Im starting to think my rpm gauge is bad or somthing because it fluxuates and will drop down then back up and when i turn engine off it moves down very slow and somtimes stays at 1000 mark and somtimes not,also on the water when it reads 4800 i can still nail the throttle more and go alot faster sending her in the 5000+ and i dont remember it doing that before (it was always at 4800 maxed out before??) so i think i need to check into that also, anyways of testing rpm gauge??? thanks to all you commrades for the help
