Having major trouble cleaning carb on '73 40hp Johnon
benji88
I recently purchased a 14' Starcraft that came with a Johnson 40hp motor, model 40E 73D. Had trouble getting it started out on the water, once we did, we could only move the throttle about half way (bad cable, replaced, goes full range now.)
The problem is that the motor has a hard time starting, and when it does it will eventually stall out. Checked the plugs, compression, and made sure fuel was making it into the carb. So I move on to cleaning the carb.
I have the service manual, but it is the one that covers a range of Johnsons.
We get everything detached from the carb (choke, etc..) and begin to take the bowl off. That took almost 2 hours!! The placement of the screws made it almost impossible to remove. We were using a screwdriver bit on a socket wrench. It is the only way we could even get a bit close to the screws for removal. After finally getting the bowl off and removing the float, we are stuck at removing the seat for the inlet needle valve.
The carb it self looks clean as a whistle but the gaskets are all shot. We bought a replacement kit but the guy sold us the wrong one so we have to get that taken care of. Is cleaning a carb supposed to be this hard or take this long? Can anyone offer any advice or tips so we can get this thing back on the water? Thanks.
benji88
Re: Having major trouble cleaning carb on '73 40hp Johnon
Thanks for the fast reply. Do you know if I have to remove the actual carb from the motor? The manual says I do not, but I just want to make sure.
Benny1963
hi benji. you need to remove carb ,if it majorly cruded ,you will need to sosk in carb cleaner. there is a faq on rebuilding carbs on her tashas daddy has givin you some links follow them to a tee the jets may need better attention .
you will need to run comp check. just to be safe lots of post on here use the search bar and you will find ,lots of stuff you can pm me if ya need to
benji88
I guess my main question is should this be so much trouble? The diagram shows me all the parts I guess I need a step by step type of deal which is why I got the manual. The screws seem like they are in such an akward place I dont see how one person could do this by themself.
Benny1963
yes the factory manual helps ,it should not be that hard
those carbs are easy getting them off well harder but you should be able to do them total in a couple of hours after soak
tashasdaddy
all you should have to do is turn the carb upside down, and remove 4 screws, and the bowl comes off. i just took one apart yesterday.
benji88
We tried taking the bowl off with the carb still attached to the engine. Is the carb supposed to be removed from the engine first?
tashasdaddy
yes. impossible if not.
Silvertip
Remove the carb from the engine, THEN disassemble it for cleaning. There is no way you can clean the carb with the carb itself installed on the engine.
