Having problems staying in gear
Bill Brasky
I've got a 12 hp sea king 54-58 model not exactly sure which year. The problem I'm having is when I open it up past about 1/4 throttle it slips out if gear and revs up. I haven't looked at it yet but wanted to get an idea where I should look, could it be as easy as adjusting the linkage ?
Thanks
orbanp
Re: Having problems staying in gear
Hi Bill,
It could be the linkage adjustment, as you mentioned, or could be that the dog clutch is getting worn. That means new gears and that could be expensive.
Good luck, Peter
F_R
Is the gearshift actually popping out of gear? Or does it stay in gear but slip? If actually coming out of gear, go ahead and think linkage, but that probably is not the real cause. Worn out clutch dogs are the usual culprit. If it is just slipping smoothly, that's a propeller hub.
Bill Brasky
The shifter stays in place, but the engine revs until its throttled down. It sounds much like a vehicle that the clutch is slipping in and out of.
Bill Brasky
I read a few things on here and someone had an issue like mine and was told the prop was spun.
F_R
I agree, a spun prop hub is a slippage, similar to spinning your wheels on the icy road. Clutch dogs & gears will bang or grind.
Bill Brasky
No grinding or banging going on. It pretty much just winds up and prop speed fails to follow, probably need to check shear pin as well .
