Re: Having trouble getting on plain, different prop time?
Not sure what year this boat is....what is the RPM operating range of the engine? Usually it's stamped on a sticker on the top of the motor somewhere. I'll speculate late 90's/early 00's...which means correct operating max recommended range is very likely 4,400 to 4,800, as that's typical for a 5.7 of that vintage...newer MPI models sometimes a bit faster, older pre-vortec models sometimes a bit slower.
So if you were only getting 4,000 rpms at absolute max top speed, then you are well below where this engine should be running, and therefor that tells me that you are most certainly over-propped for that application. So for prop shopping for that particular condition you'd want to drop at least 2" of pitch...maybe even 4" of pitch...from your current prop, depending on the actual operating range of your particular motor. Such a drop would help your holeshot/planing dramatically.
I would do that before trim tabs. I completely agree tabs can certainly help substantially....but first you need to be appropriately propped.
