Hawk Epoxy - The Premier Choice
advertisingadmin
Administrator
By Sea Hawk Paints
<p><img SRC="http://www.iboats.com/mall_marketing/newsletter/april16/images/art3-1a.jpg" border="0" />
<p><b>The Innovative Epoxy System from a Leader in the Marine Building and Repair Industry</b>
<p>Building and repairing fiberglass structures is a demanding process that requires strict adherence to proper procedures. Hawk Epoxy, manufactured by <b>Sea Hawk Paints</b>, a division of New Nautical Coatings, Inc., is an easy to use, low-viscosity, low blush epoxy system that makes building and repair jobs a breeze.
<p>This state-of-the-art system is for building and repairing boats, planes, surfboards, canoes, and many other substrates. There are also a multitude of home construction and repair projects perfectly suited for the Hawk System.
<p>The foundation of the system is the R1 Epoxy Resin which fulfills all of the different application needs with its eleven-part catalyst and fairing options. Bonding, fairing, coating, waterproofing and air exchange reduction have never been simpler.
<p><b>Precise Product Selection</b>
<p><img SRC="http://www.iboats.com/mall_marketing/newsletter/april16/images/art3-1.jpg" hspace="10" vspace="10" align="right" border="0" />Hawk Epoxy's color-coded sizing procedure ensures accuracy. Hawk is available in four System Sizes, color-coded on each resin and catalyst label. Mix ratios vary depending on which catalyst is being used. For optimal product utilization, be sure to choose the same System Size for both the resin and catalyst.
<p>Any of the six Hawk Epoxy Fillers can be used with any combination of Hawk Epoxy Resin and Catalysts, giving the user a large range of epoxy blends, all within a single system. If you need a fast cure due to schedule constraints or if you need a very thick fairing compound, Hawk Epoxy has the situation covered. After the application is cured, it can be sanded into a fine-tuned shape for the highest-quality finish.
<p><b>Start With R1 Hawk Epoxy Resin</b>
<p>The R1 Hawk Epoxy Resin is a premium blend, low odor, low blush epoxy resin used for general fiberglass repair and construction for superior adhesion, strength, bonding, filling, and moisture barrier. It has a large list of features and benefits, which include the following:
<ul>
<li>High tensile strength</li>
<li>Durability</li>
<li>Ease of use</li>
<li>Excellent bonding strength</li>
<li>Waterproofing</li>
<li>Cost effective</li>
</ul>
<p><b>Hawk Epoxy Catalysts and Fillers</b>
<p><img SRC="http://www.iboats.com/mall_marketing/newsletter/april16/images/art3-2.jpg" border="0" />
<p>Catalysts include the C1 Ultra Slow Cure, C2 Slow Cure, C3 Fast Cure and C5 Clear Finish. Which catalyst is right for a project depends on many factors, such as air temperature, structure requirements and required working time. Use this easy to use chart to help you choose the correct catalyst for your project.
<p>Fillers include F1 High Load Adhesive Fiber Filler, F2 Structural Adhesive Filler, F3 Light Density Adhesive Micro Fiber Filler, F4 Bridging Adhesive Filler, F5 Light Density Fairing Filler and F6 MicroSphere Fairing Filler. From filling large holes in boat hulls to filleting corners of wooden structures, the variety of Hawk Epoxy Fillers offer the perfect solutions.
<p><img SRC="http://www.iboats.com/mall_marketing/newsletter/april16/images/art3-3.jpg" border="0" />
<p><b>New Nautical Coatings, Inc and the Sea Hawk Paints Brand</b>
<p>A trendsetter of marine coatings, New Nautical Coatings, Inc. and the Sea Hawk brand was established in 1978 and is dedicated to bringing only the highest quality products and customer satisfaction to today's mariner. New Nautical Coatings is family owned and operated with a commitment to excellence. It provides a wide array of application specific marine coating products that include antifouling systems, primers, varnish, and resins. Now offering innovative products globally, the Sea Hawk brand has enjoyed unprecedented growth and continues to grow as its products become more in demand worldwide.
<p>Click <a href="http://www.iboats.com/Boat-Parts-Accessories/dm/keywords.hawk%20epoxy--searched.1?cm_mmc=Email-_-April2016Review-_-ArticleLink-_-HawkEpoxy">here</a> to find Hawk Epoxy at iboats.com.
