Hay all I got a new to me 1969 merc 125, I posted this in my thread and thought I should post it here also for all you prop guys, any help will greatly be appreciated !!
OK guys when I was out last night [ what a great night ] I finally have a working tack .the one is the tron is broke, I took the one out of the hustler, That one works !! well she was only hitting just under 4000 , so I know I need a few new wires on her and I think I can get a little more out of the throttle cable !! I am hitting 42 with a 3 blade alum, on there , and also need to clean the carbs on her , or should I say I am going to run some sea foam threw the next few tanks !!
OK now I don't really want to get her where we top out , that is 5500 RPM I have to check , shes a 69 125 hp merc !! I am going to start looking for a prop like a 21 at least stainless with a 2 step up in pitch i should pick up 400 rmp at least
I have a two blade that came with her, but it has a couple chip I need to get fixed !! he was telling me when I got the motor that he was getting 45 with the 3 blade bronze prop I was getting 40, with the 3 blade alum I was getting 42, With the 2 blade he said he was getting 55 out of her , with the two blade i should get 50 at least !! I am going to look for a 3 blade stainless steel a 21 !! what do you guys think !! I should post this also in the prop forum !! John
Ps she is on a 15.6 glastron tri-hull 1977
My load in the boat is 2 6gals gas tanks and 500 lbs in people.
prop is 12 3/4 inch 19 pitch make not on prop 3 blade alum
3 blade bronze we were only getting 40 mph didnt have tack working then 18pitch
running 42 at 4000 rpms with the alum
the hole boat when new was 925, should be about that now she's all new !
