Re: HD 25 1946-1950 (?) Want to make it run again.
Hi Kid<br />Glad to hear you have spark to both plugs. A nice solder job to the terminals should do it. Good job on the high tension lead, that can be a little tricky. Ok you have the fly wheel off, lets start here. Under the flywheel is a magnetic rotor (rotates between the coils), this just slides off the crankshaft, note the index key. The coils, points,and condencers,etc are mounted to the stator plate (the part you turn with the throttle control lever). On the under side of the stator plate is a tunnel with a tensioning screw in the end of it. You will need one of your longer screw driver to loosen it. This will allow you to remove the stator plate. A new condencer or pair of, might be an affordable good idea. As I stated earlier, unless your points are really far gone just redress them nicely and call it good. The last price I was quoted on nos points was around $90. a set, thats $180 for the motor. During your exploration and work you will note a ground tab on the Stator. When the throttle control is slid to the stop position ( or somewhere near there) this tab will connect and ground the ignition stopping the motor. These little motors were and are oil lovers. They need the oil for sealing purposes as much as luberication. Since most of these gems have done way more time hanging on the shed wall rather than the transom they become all sticky gooey. Inside and out. If you want you could soak the cylenders with a little Seafoam. Available at most auto part stores. this may loosen up the rings a bit. In most cases just a little mixed fuel does the trick. Point gap .020 plug gap is .030. The fuel system. This can be some what of a challange. There is a small bronze or brass screen on top of the petcock in the tank. It is soldered to the petcock. It is delicate, a tooth brush used carefully works to clean it. There is a cork float in the carb bowl mounted to side. This float is probably dry and delecate as well. It should look shelaced/varnished. this float is mounted to a brass rod. This rod is the float bowl valve ( moves up and down) The float is attached to the rod via a small wire clip at the top, this clip indexes to a notch in the rod. To remove this for cleaning,remove the screw under the rod on the bottom of the bowl. Remove three screws and the cover from the top of the bowl. Very carefully spred the clip and push the valve out the bottom of the bowl. Starting positions for the needle valves are the same as for any 1950's OMC motor. 1 1\4 turns out from lightly seated for the low speed and 3/4 turn out on the high speed. The low speed is the dial at the top of the tank. Turn for low speed air\fuel mix adjust and push it down for prime to start. The high speed needle is on the front of the motoe just under the cowl. Just a word of causion here, wear safety glasses when watching the primer function. You will be able to hear it working, this no doubt will make you curious and you will have to look. Don't get an eye full of gas. Have fun, lets us know how you make out.
