OldJohnson60
- Joined
- Jun 16, 2003
- 21
Hi there,<br />I am new to the world of outboards and just bought an old boat to fix up for really cheap. I have a 60 hp 3 cyl. johnson on it, model number 60173C. I had finally got it to run decent and i went to check the plugs and found that the middle cylinder was soaked in milky water, oil mix, and the lower had a slight amount on it, the top cylinder is fine. Is this a head gasket problem, where could I order one if it is the problem? Thank you guys so much.<br /><br />Josh
