The motor is a evinrude 30 hp 1990. I got a call from a mechanic indicating that the impellers on the water pump are melted, needs a complete water pump it. The head gasket is blown (due to heat build up), the pressure in my cylinders is 60 lbs. and that I need a neutral start switch. He indicated that he was unable to get a visual on the piston skirts? He stated that there was no melting of the aluminum.<br />My question is how bad is this? What else could have happened to the engine? The engine shut down while it was running. The lower unit was hot to touch. When the motor shut down it was idling for about 10 min.<br />Thanks in advance for your help.
