Re: Head Gasket Replacement/92/120HP Force
Gentlemen, Update, had friend come over and did compression check, 150 on all 4, then we loosened up the bottom 2 plugs and we saw water or what we thought water coming out the bottom 2 cylinders. Surely we thought the head gasket, well we pulled the head and turned over the engine and we noticed alot of extra fuel being pumped into the bottom 2 cylinders when we rotated it by hand. Cleaned everything up and put a new gasket on but it's still smoking like decarbing. Friend thinks it has something to do with the carbs, carb idle mixture adjustment needles being worn, HELP!!!!
