head gasket replacement
crxess
Re: head gasket replacement
No sealer required.
Tightening sequence is an outward spiral from center bolts. Snug all first then torque in spiral pattern.
Make sure you have the torque specs. To loose and gasket will blow out again. to tight and bolts will strip.
