Head Gasket sealer on outboards?
Steamboat
I pulled the heads on my 1997 EFI DT150 and am getting ready to re-install them and the Clymer manual says no gasket sealer needed, the Suzuki factory manual doesn't mention gasket sealers of any kind. I've seen where others on this board have advocated the use of "perfect seal" or something named very similar to that on head gaskets. Is this a preferred way of installing outboard head gaskets and if so, where can "perfect seal" be purchased?
mcfly99
Re: Head Gasket sealer on outboards?
Originally posted by Steamboat:<br /> I pulled the heads on my 1997 EFI DT150 and am getting ready to re-install them and the Clymer manual says no gasket sealer needed, the Suzuki factory manual doesn't mention gasket sealers of any kind. I've seen where others on this board have advocated the use of "perfect seal" or something named very similar to that on head gaskets. Is this a preferred way of installing outboard head gaskets and if so, where can "perfect seal" be purchased?
I purchased it at a local Merc dealer... They had it, just had to call around.
rodbolt
either quicksilver perfect seal or BRP gasket maker. same stuff different labels.
