Head issues boat
sk7499
Hi all my head broke in my boat.i boat a new unit.i installed it but the outlet discharge from the head is leaking.its the fitting from the head to the discharge pipe that later connects to holding tank.i use clamps to tighten this am I doing something wrong do I need to use some type of adhesive when I mate the discharge tube to the head drain
If your using the original hoses then it may just be the hose. Its gotten hard
sk7499
I'm using the original do u recommend new hose.. or should I use some 4000 adhesive caulk inside the pipe then clamp it
You could try adhesive, but I wouldn't use 4000, maybe something like bellows adhesive
If the hose is not fairly hard to slide on the hose barb then its probably the hose
