JohngeorgeIV
- Joined
- Apr 6, 2013
- 16
WOW...I have learned more about Boats in 3 weeks then the rest of my life added together times 100.... what started out as a "quick fixer upper" Hit a pinnacle moment last night when I was standing in my bare aluminum boat (except for two stringers) looking out at a 5 foot high pile of wet foam, wood, and General CRAP in my driveway and saying over and over..." NO big deal, No big Deal, This wont be expensive....Any one been there before?
Questions looking for feedback....
1. I have added additional aluminum stingers riveted into place because of a "Good Hook Up" so that I could go with 1/2 exterior grade Arauco Ply for my flooring. My original plan was to Use a few gallons of Spar Varnish on each side and fill all holes with 5200 on installation. Then I was going to coat the whole main floor with "tuff Coat" or that type of paint on Rubber Floor....Now I am considering roll on Vynil Flooring with Adhesive? THoughts? experience? do both stick to spar varnished Plywood?
2.) I launched my boat this morning to do a quick seepage and leak test with everything removed. I only got a small amount in the floor rivets below the transom. A coating of gluvit? Marine grade Goop? or something more intense?
3. Originally was only going to replace parts of the Foam with Foam board cut down to shape. Due to the amount of "PROBLEM AREAS" I got pi$$ed and Ripped it all out. Does it only make sense to use pour in Foam? is that superior to Foam board or those pool toy things I see people using?
4. My boat orignally had a 2 foot wide Shelf angled down directly in front of the outboard with drain holes in the bottom out through the Transom. IM assuming this was helpful for "Splash Overs". Is this piece necessary? Has anyone customized it shorter? Cuz Does take up a lot of Casting deck room!!
5. Rather then have wires running everywhere I was considering running Plast Ptex pipe or PVC pipe for conduit to the Drivers console, to the rear batteries and Lights, and to the trolling motor and Bow lights. Was going to run it right thru the poured in foam. Anyone done it? bad idea? any experience?
PLease help and Thank you for everything you have showed me so far!!
Johngeorgeiv
Johngeorgeiv
