Re: Headgasket for I6
Personally, I have always used Fel-Pro where ever possible, but not finding a marine head gasket from them for your engine. Probably would be OK to use a standard gasket on your engine, since (I think) your not in salt water.
The Merc labeled gaskets would be fine too.
FWIW, I'm about 99% sure Mercury Marine probably sourced them from an outside manufacturer, so you may be able to find a cheaper set for your engine if you drop the middle man.
