Porschesolutions
- Joined
- Jun 18, 2017
- 49
After a year of chasing issues, I finally found my FINAL problem: a warped head. It started with:
1. new-to-me boat purchase, ran rough & rich, thought it was tuning.
2. ran well at my house with fresh gas, but not on the water. Had to be towed in...wouldn't idle or plane.
3. rebuilt the carb, set the mixture at my house, still no good.
4. compression test on found 2 dead cylinders: 3 & 5. Removal of Valve cover found corroded/broken valve springs.
5. replaced those valve springs, compression back up. Boat still wouldn't idle.
6. Found bad ignition wires, distributor installed incorrectly.
7. Set timing, timing was set to 18 degrees ATDC (yes).
8. winterized boat, changed oil
9. Took boat out in February to tune, started behaving better and worked my way up to 38mph, but then wouldn't idle again, retired before we needed to be towed in.
10. found a little water in my oil, enough to dig in again.
11. found one water shutter "torched".
12. Found #6 had no compression.
13. Found broken valve springs on 4 & 6, so pulled heads. Found no cracks or obvious leaks, had intake, heads, wet-manifolds pressure-tested & fluxed. 1-3-5 head came back warped at #3, so had it decked to restore sealing surface.
14. All valves were good, so re-lapped them, installed fresh seals, bought all Marine (Mercruiser, Quicksilver, or Sierra) gaskets & will install the heads tonight.
Can't definitively find whether or not the new Quicksilver head gaskets should be coated or not, esp. where it #3 was leaking prior.
