Two AQ131D B230 Motors. Took off both heads, waiting for new heads to arrive. Should I clean the carbon off the tops of the pistons or just leave well enough alone. If I should, what is the best process to clean them. Please be specific. Should I only clean them when the pistons are at the top of the stroke? If I turn the crank to bring the other two pistons up, do I need to keep turning the crank in the same direction (clockwise) to put #1 piston back at TDC? If I turn the crank counter clockwise, will I ruin the piston rings? Thanks for all the help and answers to my posts. I am learning a lot as I continue this project.
