Hear luv leak
Sabbatical IH
Replaced upper and lower Bravo 3 due to PO crash. Runs great but I’m having a neusence leak in gear oil out of where lead propeller and lower unit connect. Is there an o ring or fitting there that needs attended to?
Don't know where is area is
The lead prop and lower unit?
There is a lube channel O ring between the upper and lower sections. Is that what your talking about?
Scott06
Were they new or used units ? Thee are shaft seals in that area
Tell me something Scott, you asking me the question or the OP?
If the OP, reply to his not mine because I have no idea where your coming from because the shaft seals have nothing to do with leaking lube between the upper and lower
Scott06
Yeah replied to wrong guy
Assumed leak is coming out from between front prop hub and lower in prop shaft area not between lower and upper ?
Confirm where leak is I assumed it is by front prop could in exhaust cavity. Post pic if you can
