Heat alarm
bluediamond46
I have a 50 hp '73 evinrude lark outboard engine,,,does this type motor have a overheat alarm horn or buzzer and if not how can i put one on it,,the SIMPLE WAY!
ezeke
Re: Heat alarm
Just to the left and up from the top spark plug you should see an opening from which a tan wire is exposed. That wire leads in to a temperature switch. If the engine overheats, the switch closes the circuit to whatever horn or light you choose to use as an alarm.
Wire a signal device to the positive side of your circuit, run a tan wire to the switch, and, if the engine overheats, the alarm will activate.
You can see the engine diagram at the BRP parts diagram for your motor.
http://epc.brp.com/default.aspx?brands=ej&lang=E
Once you have selected the year and model number of your motor, navigate to the cylinder and crankcase diagram.
The third icon at the top left of the diagram will enlarge the diagram so that you can save it to your computer as a picture with your right mouse button.
You can download the parts list to your Excel program if you choose.
Edit; if you have the original wiring harness and remote control, the horn was located inside the control. The switch at the engine usually did not go bad, but the horns did.
The horn had a positive feed off the ignition switch and the tan wire ran from the horn back to the temperature switch at the engine. See the Remote Control diagram at the BRP parts catalog for your motor.
bluediamond46
Re: Heat alarm
Hey COMMANDER,,, I found the wire but can not locate the buzzer or Heat alarm,,,where is it located,,,,
ezeke
Re: Heat alarm
"Edit; if you have the original wiring harness and remote control, the horn was located inside the control. The switch at the engine usually did not go bad, but the horns did.
The horn had a positive feed off the ignition switch and the tan wire ran from the horn back to the temperature switch at the engine. See the Remote Control diagram at the BRP parts catalog for your motor."
If your motor does not have a remote control, but is a tiller model, and, If you do not have a horn, wire one by running positive voltage to the horn and connecting the other wire to the tan wire at the engiine.
OBJ
Re: Heat alarm
As ezeke posted, if you have the control box, it will be in there....mounted just over the ignition switch. You have to take the controls apart to get to it.
If you want to see if there is one and it works, look back at the engine where the temp switch wire comes out of the block and you should find a rubber boot on that wire. Slide the boot back to expose the knife connector. Now, turn the key switch to "ON"....don't try and start the engine and you will need the battery connected also.
With the key in "ON", ground the exposed knife connector to a clean engine ground. If the horn is in the box and working, you should hear a steady tone from the horn as long as the knife connector is grounded. If you don't, as ezeke said, the horn has probably seen it's better days and needs replaced.
OBJ
Re: Heat alarm
OOPS! Didn't mean to walk on ya' ezeke......:^
ezeke
Re: Heat alarm
Not at all, I didn't think anyone was watching so I just plowed ahead.
I liked your Christmas story, OBJ. Best to you and yours.
OBJ
Re: Heat alarm
Right back at ya' ezeke.....have a great Christmas!!
bluediamond46
Re: Heat alarm
OK AD/Commander"""" Thanks for the help, I now know my HORN does work, sounds funny but works, so i guess i shouldnt have to do anything else to it RIGHT, Your help has taught me something else about an outboard i didnt know, i dont know as much as i thought i did! THANKS guys
OBJ
Re: Heat alarm
We are glad to help! Have a great Xmas!!
