What is the difference between the heat exchanger in my water heater, and a heat exchanger used for blowing hot air (heat) into the cabin areas...?
My heat exchanger for the hot water heater is using engine water, (which is raw water) to heat water while running...
I want to add heat to cabin, (air) while running using the same concept, but the heatercraft and other manufacturers, don't reccomend raw water in these heat exchangers, expecially if running in salt... or brackish
Is it just a matter of flushing regularly, or is there a model that is less sucseptible to corrosion?
Perhaps a used water heater or exchanger modified to work with a 12volt fan and some tubing?
