scandiaclay
- Joined
- Jul 18, 2007
- 4
Hi-
I have an 1994 Ebbtide boat with Yamaha I/O. When I start it up I it will intermitantly show that water level is low and heat begins to rise. It then begins to work fine once I punch the throttle and plane out. It then works fine until the next time I shut off engine and restart. It then may or may not experience the same problem. This happens about once every 7 times I start the boat. The other 6 times it starts and runs perfectly. I am not sure why pump would not pump water sometimes but not others. And why it would always work perfectly after I open up and plane it out. Any thoughts would be greatly appreciated.
