bumblebeeamigo
- Joined
- Mar 11, 2010
- 51
So I have an appointment for my winterization in 2 weeks. I was told thats when most people winterize their boats around here. The weather originally said it wouldn't freeze this weekdn, and next weekend is in the 70s. Now I'm staring at the weather report and they are calling for up to 10 hours of close to 20 degree weather. Based on everything I've read right on this forum, that is a hair too long and a hair too cold. It may be OK, it may not be.
No biggie, I ran to the store and bought an engine block heater to hold 'er over.
seems like my problem is solved until I try to get it to stick to the engine and I realize the block is aluminum. shoot.
It won't stick to the oil pan either. (never knew they had aluminum oil pans?)
Shoot. Now I'm SOL.
I tried to read the winterization stuff and its too confusing. Never heard of fogging motors or stuff like that. I'm trying to watch youtube videos and I just don't get it. Evidently i'm too stupid to make sense of these basic winterization guides.
So I drain the 3 drains I know of- no idea what each one is- one is on what looks like a coolant pipe inside the engine bay, 2 are in the back under the outdrive. 2 of the 3 drained a lot of water out, which should be good. Don't see anywhere to pour in RV antifreeze... anyway the short story is I need to learn to winterize my boat but it seems like its too much to figure out when I have 4 hours to fix it, 2 hours with stores still open. and no boat stores open anymore.
So now I'm thinking either 1. go to the store and buy one of those light bulbs that people hang with their cars (read those work), and a incadescent light bulb and that should produce another heat, or 2. Stick the engine block heater I bought somewhere else, like exhaust manifolds, the top part of the engine, or that spot that 4 coolant pipes go to on top of the engine. None are "ideal", but I figure the block heater fits, sticks, and it should create enough heat in the engine bay to keep it from freezing, right?
Anyway, I've never used a block heater so I don't know if that logic actually works. I just bought it because the forums said they don't produce a spark which is a risk with a light bulb.
Can anyone tell me if its OK to stick the block heater on top of the engine? Should I buy a light bulb or is that not enough? Or did I do enough (draining those 3 points) to reduce any risk tonight?
I know I deserve a lot of comments such as: Why did you wait so long, WHy aren't you smarter, and why didn't you figure this stuff out 10 years ago when you bought your boat. Well, the answer to all of those is: I know, shame me, but also help me get through tomorrow. Thanks!
Shoot. Now I'm SOL.
