freeisforme
- Joined
- Mar 23, 2009
- 184
I've been looking at a bit larger boat, probably about 2100 lbs with trailer and gear. I currently have been using my older Ranger 4 banger stick shift to tow my aluminum boats but I'll need to up the vehicle size a bit.
I don't want to buy new, I don't tow that often and I have to keep fuel mileage in mind. I bought the Ranger years ago since it gets over 24 mpg and still can pull about 1500lbs or so with no problems, but launching anything over about 900 lbs or so is iffy.
I've been considering several vehicles, both Ford, either a 1994-1996 F150 or a same era Ford E series van. I'd want the 4.9L engine, which should be fine for towing what I need to haul, and either a 5 speed stick or AOD automatic.
I figured that this combo should still be able to get in the 17-18 mpg range empty so I can still use it for everday use. It would have to replace the old truck, so keeping both isn't an option due to insurance costs.
Blue book value on anyone of these is in the $3000 range for a clean example, (If I can find any such thing).
Does anyone have any other vehicle suggestions? I don't want 4x4, there's no need for it here, and its just more to maintain and more weight to drag around. The same for the larger E4OD trans.
I'd strongly prefer to stay with something newer than 1994 or so, it has to have A/C, and has to be a longbed. Trailer tow and other options won't be an issue with the weight of trailer I need to pull either.
I actually hate to sell my Ranger, it's been a great truck and it's super clean for being over 100,000 miles. I figure I can almost sell the Ranger for about the same amount as what I need. NADA and KBB both put them within a few hundred dollars of each other in value.
What I do notice is a lack of clean used trucks, everything I see has 150,000 miles on it. I really don't want anything over 75K.
I lean towards a the E150 over the pickup since it lets me lock everything inside and I don't have to buy a cap for it. I have hitches to fit either vehicle here from past vehicles owned. The truck has a bit better visability and traction but if I find a window van, that should'nt be an issue. ( I used a 1989 Ford E150 Conversion van with little to no rear visibility for years to launch with years ago with no problems).
I looked at new trucks, even drove a new F150 last year for two days, the mileage was just plain bad out of the 4.6L and I didn't like the truck. I really like the older vans, like the 1989 I had, but the A/C system being R12 and the hassle of getting those years through inspection for emissions here with the new testing just isn't worth it.
Any thoughts?
Any thoughts?
