Don't believe your performance numbers until you verify with GPS and a known tach. Tachometers can easily be up to 500 rpm off at the high end.
With big block you are pretty much at the higher end of the capability of an Alpha.
Mercury changed to the Bravo for a reason. Yours probably will "hold" as long as you don't "Straight Arm" the throttle a lot and you do not do a lot of WOT running. (why have a BBC in it then?)
Your other choice could be to run it until it blows and replace the whole mess with a Bravo I or III (I would vote for the III) Of course if you do that you won't have much to resell....
My Best choice (if just cannot turn loose of the boat) would be to pick up a used Bravo drive/transom/raw pump etc, and swap it out and sell the alpha stuff. There's always someone needing an Alpha.
You have to remove the drive, remove the cap and the input shaft, then you can get the gears out and you have to look at the shoulder on the gears, the heavy duty units are much thicker than the regular versions and use a thinner roller bearing. It sounds more difficult than it actually is to do. If you are at all mechanically inclined you can do it. But without a set of gears to reference I don't know if you'll recognize the difference. I have a set of the regular-duty gears laying around here somewhere. If I can find them I'll measure them for you and post. Other than that there is no way to know. The 1.32's would be a mistake I think and you may have a set in there which would be why you can't hit your rpm window. With a 21 pitch prop on there and 1.5's you should hit 5000 rpm easily unless the boat is waterlogged or soemthing is wrong with the engine.Super Nova is there any way to check that? Also anyone have a thought about the WOT speed?
I believe the 454 min HP is 330, But I am probably wrong about that>
