Re: Hekp stuck rudders
You need to remove the rudders? That could take a couple a days of wrestling. The packing is in the rudder packing nut itself on alot of them, if that helps.
If I have to remove any rudders again I'll consider using some heat from maybe a heat gun, from under the hull. With all the safety considerations first and foremost.
The Paragons are overbuilt transmissions from what I've been told by a rebuilder/supplier in FL.
