Help ! 1972 mercruiser trim tab removal
muskrat808
Hi-replacing water pump for first time in 1972 140 hp mercruiser . Have all bolts loosened /removed except for the hex under the trim tab . Seloc manual and all internet postings say "remove trim tab " to access the hex nut, but how ? Does it pop off , unscrew or is there a nut /bolt I'm not seeing ? Thanks
Don S
Re: Help ! 1972 mercruiser trim tab removal
Just pop the little plastic plug out of the hole in the upper unit and use an allen wrench to get to the bolt.
attachment.php
Ayuh,... It's a 3/8" allen wrench, down through the hole above it....
If it's to corroded, a propane torch will melt it outa the way....
ziggy
i soak mine with some pb blaster a few days prior to removal. then be sure ya got a good grip on the cap screw with the hex wrench. i usually put a lever (crescent wrench or the likes) on the hex wrench too.
muskrat808
Thanks everyone . Bt the way what's pb blaster?
ziggy
pb blaster is a rust/corrosion penetrant. like wd 40 (which is not a lub, but a rust penetrant too) but much better.
i use it on that bolt so i give myself the best chance of getting that particular bolt loose. i don't want to strip the drive of that cap screw down inside the drive. i remove that bolt yearly and it still goes 'snap' (when it breaks free of the trim tab) every year when it frees up to remove it.
dpoff
I have found that before you put the allen wrench in, take a pick or small screw driver and poke around inside the bolt head to make sure that there`s no crud in there to make sure that you get a full bite when you go torque`n with the wrench.
