okay I have just purchased a 1979 9.9 evinrude I replaced the water pump and housing, cleaned the fuel pump and rebuilt the carb. It will not stay running it will start if I pull the choke out but then it starts to die and I have to play with the choke, pushing it in and out to keep it running. All the while the throttle is in the start position if I back it off at all it dies. Any suggestions would be much appreciated.
