Here's the story:
bought a 97 cajun with 200 johnson outboard venom. Boat has been sitting for several years. Drained old gas, changed out plugs and took the boat out. Boat would not plane out, would not get above 2500 rpms. It cranks every time but does not have power. Took to mechanic, they decarbed carburators, changed plugs, checked compression. They took boat out for a test run and said it ran fine.
Got boat back and took out and for the first 15 minutes ran good and then it started to lose power, would not plane out. So I put in neutral and reved up the motor seems like it reves up good and put in gear and still just will not plane out, It also dies after I let off the throttle, but it will start right back up. Gas cap broke off, so I have the port plugged up to keep fuel from spilling out of the boat.
What could be the problem, what do I need to check.
Thanks for any help....
