Re: Help 72 Johnson 50HP
Hi Scorpionhand<br /><br />Its not uncommon to see someone changed the old type ignition to new CDI. On many models they bolt right on, if you can get one from a wrecked motor. On one of the frost plugs it has the model numer stamped. Try to compare to the number on the bracket. If your still in doubt - post both numbers here. It can be hard to repair motors like that ( if thats the case ) as you have to order parts from several vintages !
