FISHBONE74
- Joined
- May 2, 2008
- 19
I HAVE A 1979 JOHNSON SEA HORSE 35 HP I HAVE REPLACED THE IMPELLER 2 TIMES NOW AND WHEN I TRY TO START THE MOTOR I HAVE GOOD WATER FLOW OUT OF THE PEE HOLE BUT AS SOON AS THE ENGINE TRYS TO START THE WATER STOPS AND WHEN THE WATER COMPLETELY STOPS THE ENGINE WILL START AND IDLE BUT AT THAT POINT I HAVE NO WATER GOING THROUGH THE ENGINE THEN I SHUT IT DOWN AND TRY TO RE CRANK AND IT WILL TURN OVER FOR A LONG TIME AND ALL OF A SUDDEN I HAVE WATER AGAIN AT THE PEE HOLE AND WE REPETE THE PROCESS IT IS LIKE SOMEONE IS TURNING THE WATER VALVE ON AND OFF PLAYING A TRICK . CAN ANYBODY HELP ME ON THIS ONE
THANKS IN ADVANCE
FISHBONE74
THANKS IN ADVANCE
FISHBONE74
