Help...85' Force 85hp not running right (long)
4runneradam
Bear with me here, I'm a brand new boat owner, and a beginner automotive mechanic.
I bought a 1985 Bayliner Capri with a force 85 last September. First 2 times I put it in the water, it ran great. Good throttle response, and I could get i t up to 35-40mph. 3rd time in the water, all of the sudden while cruising it lost all power, and stalled. I got it to fire back up, but it would only idle. I found out later that my father in law had put some old gas from another boat into my tank. I thought this is what caused the problems since he also put bad gas in another boat and it won't run either. So I pulled the engine cover off and noticed some black oily residue leaking from the spark plug cylinders. I replaced the spark plugs, and mixed up some fresh gas, 50:1. It now runs better, but still not right. I can only get it up to 20-25mph, and it has horrible throttle response. Feels as if the choke is half way closed or something. I checked the choke, and its all the way open, and the throttle is opening all the way as well. Ran it out of the water on earmuffs and it seemed to run pretty good, but still only half power on the water. Boating season was over, so my father in law drained the lower gear case oil and put it up for the season.
Fast forward to yesterday. I mixed up a fresh batch of 50:1 gas, and get it back out on the water. Still runs bad like it did last season. After about 20-30 minutes of running around the lake, right as were going to pull it up on the trailer, I hear a loud buzzing sound under the dash. I shut the boat off, turn the key back on (but not starting engine) and its still on. Get back to the house and its not coming on anymore. We hook it up to the earmuffs, fire it up, let it run for about 10 seconds, and it never pumped any water out. So I'm guessing the water pump isnt working, and that the impeller is broken, and that buzzer sound we heard earlier was a high temp warning.
Do you think the water pump not pumping would cause the poor acceleration and bogging out? It was working before, maybe just not very well.
Also, I took off the air induction cover that connects to the carbs and it had some oil sitting in the bottom of it. Is there supposed to be an air filter inside there, because there wasn't. Is the oil in there bad? I know 2 strokes are messy.
Any suggestions on what to try next? I'm definetly going to put a new impeller on, but what if that doesn't fix the problem? Could the old gas have messed something up in the carbs? Do I need to take the carbs off and soak everything in carb clean? Do I need to get rebuild kits for the carbs? Or do you think it might be something with a weak spark? I need to bring my spark tester with me next time and see. Should I do a compression check? What should the cylinders be at? Geez...guess I need to drop $50 and get a manual.
Hope you guys can help, I'm at a loss since I'm quite unfamiliar with this motor (and 2 cycles in general)
MWBROWN
Re: Help...85' Force 85hp not running right (long)
I have a 1985, 85 hp.
Yes, the buzzer is the overtemp alarm.
It sounds like a broken impeller, but muffs don't work well. Need a large tote from Wally Mart to put it in for testing.
There is no air filter.
If the original gas has stuff in it maybe the carbs need cleaned out. That could make it run poorly. There is a screen under the plastic cap where the fuel line connects. That could have stuff in it, thus blocking the fuel. If it is running lean, that could also make it over heat.
There are others that know more that I about that stuff.
That is all I have for now. Good luck.
Mike
joshdashnaw
One thing I read is that any time you service any part of the engine you need to adjust the timing and synchronization. My repair manual explains it well I suggest you invest in one if you don't already have one.
4runneradam
Interesting.
Thanks guys!
Anywhere to get the manual cheaply? Online download or something?
lotusing
First off,replace the impellor then go to a mercury marine store and pic up a can of mercury power tune and follow instructions.My engine was running ok but not great.Used that stuff and now runs strong.
4runneradam
Re: Help...85' Force 85hp not running right UPDATED!
I replaced the impeller today, and it pumps water now.
I figured out what the problem was. I changed spark plugs, and the middle cylinder's spark plug was clean, so it wasnt firing. Hooked up my spark tester and it wasnt getting spark. I took the coil board off, and looked through the wiring. Not sure of the part names, but there are 2 large boxes (switch boxes/CDI??) that power the 3 coil packs. The middle coil pack is not putting out spark to the plug. So I unhooked the 2 red and orange input wires from the switch box/CDI, swapped them from one coil to the other, and now the middle cylinder is firing and the top cylinder isnt. So that right there tells me the large box (switch box/CDI?) is not sending voltage to the coil pack. So that means the switch box/CDI is bad right? I diddnt see any numbers on the box, other than made in the usa. It looks a lot like this http://iboats.com/116_5301_Switch_B...4627176--**********.500949678--view_id.335731 but has a white wire coming off that I dont see in the picture. $240! I wasnt expecting it to cost that much!
Now for my next question. It appears that that each of the CDI boxes will fire 2 coil packs, since they each have 2 outputs. My Force 85 is a 3 cylinder, so there is one unused output (orange). Would i be able to use this unused output instead of the faulty one on the other CDI? Or will the firing order be messed up?
roscoe
yes, you can use the un-used output.
4runneradam
Awesome, that would save me $240!
rainier78
hello i have a 1985 85 hp force an i had the same problem with my cdi box yes you can use the orange wire but it is going to put the motor out of time what i did was i swicthed the boxes an wires there is two plug ins that goes to the boxes swicth them so you can use the 4th or orange wire for the one that is not getting the spark it is really hard to tell you how to do it when i get a chance i will take pic an show you what i did
4runneradam
Thanks for the help...but this thread is 3 years old! My problem turned out to be a bad stator.
bashr52
How did a bad stator cause it to run poorly? :confused:
vscgraphics
I will take those pics... I did the same swap...and it sounds like it it out of timing
4runneradam
It's been a while since I worked on it, but I do beleive the stator has multiple outputs that feed the CDI boxes, and one of those outputs was shorted out while the others were fine.
