Re: HELP!!! 90 hp merc '78 model won't start
I got the it started, thank you. I hooked up a water hose to the water intake as suggested by the manual, but hardly anything comes out the water exhaust, but then I only let it run a second, just enoughto see if would start. The problem was the enternal wiring harnass was not allowing enough voltage for the coil to produce adequate spark. The harnass was badly corrided, and not wanting to spend $150 for 1 moded plug and 8 short wires, I found the plug at WW Grainger Electrical Supply, and built a harnass. thanks again Jim
