PaulAlford
- Joined
- Aug 22, 2009
- 12
I am looking to purchased a used 1994 Astro boat with a 115 HP 1995 Mercury outboard on it. Both are in decent shape. Engine has been sitting a while, not used much. It started right up, idled fine, rev'ed up fine, smooth, shifted into forward and reverse with solid clicks into gear, trim and tilt is fine. The only thing I noticed was the water discharge was about half of what I thought it should be. Pretty slow stream and pressure, but he did admit the waterpump hadnt been replaced since he had it (2 years) and who knows before that so it could be just an old water pump/impeller (which I can replace.. I think since I did my current 45 HP Mercury.)
I am going back it 2 days to put it in the water and plane it and let it get up to temperature... but is there any other simple advice or simple things I can do to check it out before I buy it ? I am a novice and NOT a mechanic.
Thanks in advance and please hurry with some ideas.
Paul
Paul
