Hi,
I had to do my two year impeller change yesterday and for some reason I can not get the whole gear shift and alignment to play nice. After 2 hours and a sore back, I abandoned ship.
I have the shifter in forward and I have turned the lower shift shaft clockwise to engage the prop in a right hand propulsion (forward). When trying to get the lower housing reattached to the upper housing, I am not having any luck. It will only go up so far but will not fully seat. The one time I did get it aligned and bolted, the prop would no longer turn in any direction. I don't remember it ever being this hard. Maybe I am forgetting a step? Do I need to turn the upper shift shaft as well? Also, is there supposed to be a gasket or sealer between the upper and lower housing?
Thanks in advance for your replies!
Ron
Ron
