Robbie Davis
- Joined
- Jul 16, 2002
- 13
Last week upper gears in 87 alpha 1 went out and I have it apart to overhall
Im now disasembling the lower case and everything has gone just right except after removing the thin nut on that holds the pinion gear to the lower driveshaft and removing the locking collar at the upper bearing . and was able to remove the bearing race and shims. but I am not able to pull the shaft out because the gear is still stuck on shaft . I have 1/8 inch free play up and down and have tried to snap shaft up and down to try to remove gear . but for some reason it wont move.
Instructions say it will slide right off . this one just not happening.
Has this happened to anyone else any advice please
thanks Rob
thanks Rob
