hey folks, i have a 1984 erude 150 that is used on a 1894 welcraft step-v..a pretty heavy boat. i have always turned 4800 rpm's at wot and run about 36 mph. all the sudden i am turning 4000 rpm's and running 28-30 mph. i know the rpm's were low anyway but thats the way its been since i bought it. i have 95 on all cylinders on compression test, i have replaced the coils, plugs, plug wires, fuel lines and filter and cleaned the carbs. this is a pre-mix engine. i can't find the problem and was hoping you folks may have an idea. THANK YOU all for reading and helping!
