Help! Bayliner 175 No ignition or buzzer sound!
hawaiiboyy517
I have a 2007 Bayliner 175. All of my acc. work ie blower, bildge, horn, stereo etc. My battery is 100% charged. All fuses are good on the board. Even the 50amp fuse on the pos. lead from the battery is good. The ground cable is clean and secure!
when the boat used to start i would move the key 1 position and get a warning buzzer, one more turn to the right the motor would start.
now I get no buzzer in the 1st position and not even a click in the 2nd position.
why? I appreciate help thanks! Tom
Dave.Mishchenko
Re: Help! Bayliner 175 No ignition or buzzer sound!
Did you check the lanyard kill switch on the throttle control?
NYBo
The kill switch won't prevent the starter from engaging.
Check the main circuit breaker on the engine itself.
